Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement
  1. Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement, Blade Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement, Blade Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement, Blade Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before you begin, make sure to power off and unplug the device from the outlet.
    • If the clear water pump hose is connected, remove it now.
    • Loosen the plastic knob holding the saw's cutting head in place.
    • Lower the cutting head while keeping it steady.
  2. Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the knob.
    • Remove it from the cutting head.
  3. Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen the plastic knob holding the blade cover in place.
  4. Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Loosen the wing nut on the blade cover pivot shaft.
    • Remove the wing nut and accompanying washer.
  5. Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pivot the blade cover up and pull it off the shaft.
  6. Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement, Blade: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement, Blade: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement, Blade: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the provided spanner wrench into one of the four tightening holes on the inner flange behind the blade.
    • Use the the provided nut wrench to loosen the hex nut while providing counterforce with the spanner wrench.
  7. Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the hex nut.
    • Remove the outer flange.
  8. Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the cutting blade.
    • The blade can be sharp, so handle with care.
  9. Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement, Cutting Head: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement, Cutting Head: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mk Diamond Wet Saws MK660 2010 Cutting Head Replacement, Cutting Head: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the entire cutting head straight off the shaft holding it in place.
Carsten Frauenheim
144,649 crwdns2915208:0crwdne2915208:0
crwdns2935297:0422crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:021,096crwdne2935297:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 158
