If your Miyoo Mini Plus buttons aren't working well or just want to the replace them with different colors, this guide will help illustrate how to replace your old face buttons on your Miyoo Mini Plus with new buttons, this will give you the step-by-step process of taking your console apart to put in new buttons. We hope this helps!
Before beginning, make sure to power off the Miyoo Mini Plus and disconnect it from any external power source.
Place the device face down on your work surface.
Use a Phillips #1 screwdriver to remove the four 1.8 mm screws.
Carefully lift the battery from socket, but do not pull on the connection. The battery will still be connected to the console.
To remove the battery, follow the wires to the connecter slot and carefully pull out the connection directly from the socket.
Remove the two Phillips screws to inside the battery compartment.
Insert a thin prying tool in the seam and pry around the perimeter until the case separates.
Remove the two Phillips screws on the motherboard.
Remove the ribbon cable from the console. To do this, there is a small black clip that locks the ribbon cable in place. To unlock this clip, simply flip the black clip vertically.
Pull the cable to the left to remove it from the socket.
Remove the motherboard from the front housing. There may be some adhesive preventing you from pulling the motherboard out, but you can still remove the board by carefully pulling from the edges.
You can now see the backside of the face buttons. Pull out the center, start, and select buttons as they fall out easily and replace them with new buttons.
The #00 Philips bit was too small for the screws on my device, and I found that the #1 Philips bit was the correct size. Also worth mentioning that the two motherboard screws were eventually eliminated from newer devices, so some users may not find screws in those two holes.
