Lift the black cover off.
Remove all 4 Phillips #2 screws.
Remove the two 24mm Phillips #2 screws.
Remove the three 8mm Phillips #2 screws.
Lift the back and pry the back off.
Remove the four 5mm nut screws.
Remove the seven Phillips #1 screws.
Remove all the cables.
Remove the four screws.
Pull the motherboard up and off.
Now you can replace it with a new one.
