Mitchell Epic Series E150 Disassembly
  1. Mitchell Epic Series E150 Disassembly, Removing the Spool Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Start by removing screws 1,2, and 3 with a small phillips screwdriver.
  2. Mitchell Epic Series E150 Disassembly, Removing the Spool: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the spool from the reel, making sure that the small rubber centrifugal brakes don’t fall off.
  3. Mitchell Epic Series E150 Disassembly, Removing the Center Body from the Handle Plate: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen fasteners 4, 5, and 6 with a flat blade screwdriver.
    • Separate the center body of the reel from the handle plate.
    • Remove screw 9 holding in the retaining cap.
  4. Mitchell Epic Series E150 Disassembly, Removing the Handle: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove retaining clip r1 with a flat blade screwdriver
    • Note: It is very easy to accidentally lose this retaining clip, be sure to hold the clip while prying with your flat blade screwdriver
  5. Mitchell Epic Series E150 Disassembly, Removing the Handle: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove washer ,w1, under retaining clip r1.
    • Remove handle retaining nut, n1, using a small adjustable wrench.
    • Remove handle.
  6. Mitchell Epic Series E150 Disassembly, Removing Star Drag Assembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove handle spring washer, w2.
    • Remove star drag assembly, STA, by turning it counter clockwise while holding. the shaft it’s sitting on.(You can use the adjustable wrench to hold the square. part. of the shaft.)
  7. Mitchell Epic Series E150 Disassembly, Removing Cast Controls: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mitchell Epic Series E150 Disassembly, Removing Cast Controls: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove cast control knob, CCK.
    • Remove cast control spring, CCS.
  8. Mitchell Epic Series E150 Disassembly, Removing Drag Assembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mitchell Epic Series E150 Disassembly, Removing Drag Assembly: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mitchell Epic Series E150 Disassembly, Removing Drag Assembly: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove main shaft bearing, MSB, drag pressure insert, DPI, drag washers, dw1, dw2, and drag spring washer, dsw.
  9. Mitchell Epic Series E150 Disassembly, Removing Set Plate: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mitchell Epic Series E150 Disassembly, Removing Set Plate: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove screw 7, and 8 with a phillips screwdriver.
    • Remove set plate assembly, SPA.
  10. Mitchell Epic Series E150 Disassembly, Removing Rotating Assembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mitchell Epic Series E150 Disassembly, Removing Rotating Assembly: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove crankshaft assembly, CSA, and reverse lockout claw, RLC.
    • Slowly remove thumb latch, TL, to avoid losing the return spring.
    • Remove washers, w3,w4.
    • Remove screw, 10, holding down latch keeper.
  11. Mitchell Epic Series E150 Disassembly, Disassembling Drag Gears: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove drag pressure plate, DPP, from crankshaft assembly.
    • Remove main gear, MG from crankshaft assembly.
  12. Mitchell Epic Series E150 Disassembly, Disassembling Center Body: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mitchell Epic Series E150 Disassembly, Disassembling Center Body: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove line guide cap, LGC, with a flat blade screwdriver.
    • Remove line guide retainer, LGR.
    • Remove line guide gear retainer, LGGR, by pushing it off with a flat blade screwdriver.
  13. Mitchell Epic Series E150 Disassembly, Disassembling Line Guide: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove line guide bushing, LGB.
    • Remove line guide shaft, LGS, by pushing on the side that the line guide bushing was removed from.
To reassemble your fishing reel, follow these instructions in reverse order.
Kaden Morgan
crwdns2935283:002/26/23crwdne2935283:0
218 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 76
