Ensure that the lens cover is fully closed.
Using the iFixit Jimmy (or similar tool), pry off the front bezel, starting at the opposite end to the lens.
Turn the projector over and remove the rear bezel in thesame way. (You can start at either end.)
Remove 7 screws from the front.
Remove 5 screws from the back.
Using the jimmy (or similar) release the clips retaining the top cover, starting at the front on the lens side (as shown).
Repeat on the other side, starting at the front or the back, whichever accepts the jimmy most easily.
Lift off the cover, gently releasing a remaining clip behind the buttons, if it's still engaged.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Before doing anything else, release the battery connector, easing it with a pair of tweezers so as not to strain the wires.
In the same way, release four connectors with red, green, blue and black wires
Similarly, release the fan connector, two connectors to the focus motor and an adjacent sensor board, and the two speaker connectors.
Very gently lift the locking tabs on three ribbon connectors. A plastic prying tool is good for this. Withdraw the ribbons.
Carefully peel back the copper foil covering the video connector until you can unmate it. Try not to tear the foil.
Remove 4 screws securing the motherboard.
You should now be able to lift the motherboard clear, moving disconnected cables out of the way as you do so.
If required, you can now easily remove:
the buttons board
the speakers
or the lens cover sensor.
Remove a screw at the right hand end of the cover between the fan and the grill. (The screw at the other end was removed in removing the motherboard.)
Lift off this cover. Note that it's a snug fit. On refitting, ensure that the screw holes are correctly aligned with the pillars the screws scew into.
Lift the tape securing the red, green, blue and black wires to the battery so as to free those wires.
Remove 3 screws retaining the optical assembly. The entire assembly can now be lifted out.
Remove 2 screws securing the fan. This can now be lifted out allowing any dust build-up on th grill to be cleaned out.
The battery is securely glued to the base of the projector. If you need to remove it, take great care not to damage it as you do so.
As you apply a continual upwards force the adhesice should very slowly give. Gentle warmth should aid the process but on no account rush it. Insert packing underneed as it lifts to prevent the adhesive taking hold again.
Any idea on where I can get a replacement battery for this projector? Mine doesn’t hold a charge anymore.
Please tell us which country or region you're in, and maybe someone will be able to help you. Alternatively, if you hunt long enough on aliexpress.com you may find what you need.
I’m from the the USA, but I was curious about the specifications of the batter. I’m trying to avoid taking it apart until I have to since it still works while being plugged into the barrel plug.
Can you provide pics of the text and details as shown on surfaces of the battery? So we can try to hunt that on aliexpress.
Kitts -
These batteries are also used in R/C Helicopters and Drones.
You may try Pegasus Hobbies in Montclair, Ca.
I also need a replacement battery. Does anyone know the full battery specs (size, voltage, amperage, etc)?
Excellent article. Easy to follow and you saved life in my projector. Thank you.
Richard - UK
Hi did anyone receive information on the battery type for replacement? Mine isn’t charging either. In Australia. Thank you
Bonjour pour les fils noir bleu orange jaune et rouge du moteur de la lentille, quel est le sens couleur. ?
