With the help of a thin tool, lift the white edge between the upper body of the device and the touchscreen marked by the green arrows.
With the help of a thin tool, separate the upper body from the bottom, inserting the tool between the two parts marked by the green arrow.
Open the device.
Remove the Scotch tape and disconnect the touchscreen connector by lifting the safety tab, located at the yellow arrow.
Use a heat source to help remove the double-sided tape.
Insert translation here
To reassemble the device, follow the instructions in reverse order.
crwdns2934873:0crwdne2934873:0
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Il tablet non si carica e non si accende e anche sotto garanzia. Come possiamo fare
Il tablet non si carica e non si accende. Come possiamo fare è anche sotto garanzia
Valuti di portarlo in assistenza ed avvalersi della garanzia. Saluti
Smilzo -
