Before you start the replacement process, make sure that you have the proper repair tools, a Philips PH0 head and tweezers. You should be careful not to exert too much pressure/force on the components.
This guide will be able to walk you through the steps to replace your Mio ALPHA 2's motherboard.
Remove the four 6.7mm JIS #00 screws from the back cover.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove the four 3.8mm JIS #00 screws from the motherboard.
Remove the motherboard with tweezers
