Replace your viewfinder if it breaks so that you can see through the camera to take pictures.
Use a small coin to untwist and open the batter compartment door.
Remove the two batteries from inside the battery compartment by individually pulling each out.
Unscrew the (1) black Phillips #00 5mm screw from the bottom of the battery chamber.
Remove the (2) black Phillips #00 5mm screws that lie on either side of the view finder.
Remove the (1) black Phillips #00 5mm screw from underneath the flash hood.
Once all screws are removed, the top of the camera should come off easily.
Remove the (2) black Phillips #00 5mm screws that hold the viewfinder.
