Minolta QTsi Maxxum Shutter Button Replacement
  1. Minolta QTsi Maxxum Shutter Button Replacement, Shutter Button: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the battery compartment on the bottom panel of the camera.
    • Open the battery door by using a coin.
    • In the counterclockwise direction, twist the coin in the battery door groove to open it.
  2. Minolta QTsi Maxxum Shutter Button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Two batteries are located inside the battery chamber.
    • Remove the two batteries from the battery chamber by picking them up.
  3. Minolta QTsi Maxxum Shutter Button Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There is a screw located underneath the batteries in the battery compartment.
    • Unscrew and remove the (1) black Phillips #00 5mm screw from the battery compartment.
    • Ensure good lighting before attempting to remove this screw because it is hard to see inside the compartment.
  4. Minolta QTsi Maxxum Shutter Button Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • From underneath the flash assembly, remove the (1) black Phillips #00 5mm screw
    • Be careful because you can lose the screw
  5. Minolta QTsi Maxxum Shutter Button Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The only screws remaining that hold the top panel of the camera in place are located next to the view finder.
    • Remove the (2) black Phillips #00 5mm screws from both sides of the view finder.
  6. Minolta QTsi Maxxum Shutter Button Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Minolta QTsi Maxxum Shutter Button Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The top panel of the camera should now be easy to lift off. If it is not, make sure that all screws and attachments, listed in steps 1-5, have been removed.
    • Once all screws are removed, lift the top panel from the camera.
    • Be careful when removing the top panel because there are wires connected to it.
  7. Minolta QTsi Maxxum Shutter Button Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a metal spudger to push the button out of its socket so that you can place a new one in its place.
Jordan Ellery
crwdns2935283:010/10/16crwdne2935283:0
388 crwdns2915208:0crwdne2915208:0
Sam Houston State, Team 12-4, Blackburne Fall 2016 crwdns2935289:0Sam Houston State, Team 12-4, Blackburne Fall 2016crwdne2935289:0
SHSU-BLACKBURNE-F16S12G4
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 566
