Minolta Dimage Xt LCD Screen Disassembly
  1. Minolta Dimage Xt LCD Screen Disassembly, Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Minolta Dimage Xt LCD Screen Disassembly, Casing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Minolta Dimage Xt LCD Screen Disassembly, Casing: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate and remove the silver screws on each side of the camera.
    • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
  2. Minolta Dimage Xt LCD Screen Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Minolta Dimage Xt LCD Screen Disassembly: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Minolta Dimage Xt LCD Screen Disassembly: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Then, carefully pry apart the front and back outer casing away from the internal components.
    • Be aware of the ribbon wire that will disconnect when the casing is detached.
  3. Minolta Dimage Xt LCD Screen Disassembly, LCD Screen: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The LCD screen has wires connecting it to the rest of the camera. A bracket holds the LCD in place, so there are no screws beyond this point.
    • The screen also has a ribbon wire connected at the bottom of the screen.
  4. Minolta Dimage Xt LCD Screen Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Minolta Dimage Xt LCD Screen Disassembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Detach the connector at the bottom from the LCD screen.
    • Starting from the side or a corner gently slide the spudger underneath the screen.
    • Press the tip of the spudger down as far is you can and slowly pry the LCD screen away from the bracket.
  5. Minolta Dimage Xt LCD Screen Disassembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The screen is not detached. Wires are still connecting the screen to the camera at the bottom corners, but it is removed from the bracket.
    • Check to make sure the wires are connected, so it will receive proper power supply.
    • To remove the bracket from the LCD screen, remove two 1.5 mm screws using the Phillips #00 screwdriver.
To install a new LCD screen you will have to reconnect the wires and properly place them in the bracket. Make sure to reattach the ribbon wire before finishing repairs.
Keith Sechrist
crwdns2935283:003/11/13crwdne2935283:0
22 crwdns2915208:0crwdne2915208:0
Clemson, Team 12-4, Benson Spring 2013 crwdns2935289:0Clemson, Team 12-4, Benson Spring 2013crwdne2935289:0
CLEM-BENSON-S13S12G4
Great procedure, thank you.
Do you know where I can buy the LCD replacement part?
I have a Konica Minolta Dimage X1 8.0 MP
mscir - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,187
