Minolta Dimage Xt Flash Capacitor Replacement
  1. Minolta Dimage Xt Flash Capacitor Replacement, Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Minolta Dimage Xt Flash Capacitor Replacement, Casing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Minolta Dimage Xt Flash Capacitor Replacement, Casing: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate and remove the silver screws on each side of the camera.
    • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
    #000 bit seems to work better. There are seven screws in total (2 on either end and 3 on bottom).
    Doug Ewing - crwdns2934203:0crwdne2934203:0
  2. Minolta Dimage Xt Flash Capacitor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Minolta Dimage Xt Flash Capacitor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Minolta Dimage Xt Flash Capacitor Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Then, carefully pry apart the front and back outer casing away from the internal components.
    • Be aware of the ribbon wire that will disconnect when the casing is detached.
    Lens cover can be accessed without removing rear housing. I was able to lift off the front to access the lens cover mechanism while leaving the rear in place.
  3. Minolta Dimage Xt Flash Capacitor Replacement, Flash Capacitor: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Minolta Dimage Xt Flash Capacitor Replacement, Flash Capacitor: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Caution: Touching the capacitor leads may cause serious injury. Use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
    • On the front side of the camera, locate the flash battery holder.
    • Lift the housing and remove the battery.
    • After removing the battery, clip the wires and solder the replacement battery.
Qqq
crwdns2935283:003/11/13crwdne2935283:0
19 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 1,124
