crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Mini muscle massage guncrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Mini Muscle Massage Gun, Mini Muscle Massage Gun: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mini Muscle Massage Gun, Mini Muscle Massage Gun: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mini Muscle Massage Gun, Mini Muscle Massage Gun: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Device Overview
    • Dimension.
    • Red :98.30mm
    • Orange:116mm
    • Yellow:132.82mm
    • Diameter dimension
    • Red: 48.62mm Diameter
    • Hello 98.8mm Diameter
  2. Mini Muscle Massage Gun, Screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mini Muscle Massage Gun, Screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mini Muscle Massage Gun, Screws: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove and disassemble the shell. Follow these instructions.
    • Unscrew all the screw hi lighted in the images.
    • unscrew the cap located at the tip of the device.
  3. Mini Muscle Massage Gun: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mini Muscle Massage Gun: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mini Muscle Massage Gun: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Twist and remove the cap located on the back. hi lighted in red.
    • Carefully removed the connector from the PCB
    • Twist and removed the bottom cap. Hi lighted in yellow
  4. Mini Muscle Massage Gun, Dimension internal components.: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mini Muscle Massage Gun, Dimension internal components.: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Battery length.
    • Orange. 66.64mm
    • Yellow: 71.28mm.
    • Battery Diameter.
    • Blue 42mm
    • Massage conector
    • Red:103.13mm
  5. Mini Muscle Massage Gun: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mini Muscle Massage Gun: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mini Muscle Massage Gun: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the top shell from the body.
    • Using a screw driver removed part hi lighted in red from the motor
    • Remove screw hi lighted in yellow. Removing this screw will disconnect the motor to the body.
  6. Mini Muscle Massage Gun, Teardown components weight Shell: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mini Muscle Massage Gun, Teardown components weight Shell: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mini Muscle Massage Gun, Teardown components weight Shell: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Device handle shell is weighted at 50g . Made from ABS plastic. Injection mold
    • Top shell is weighted at 19g. Made from ABS plastic
    • The tip which is used to hold the shell parts together is weighted at 19g. Made from ABS plastic
  7. Mini Muscle Massage Gun, Teardown components cap: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mini Muscle Massage Gun, Teardown components cap: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mini Muscle Massage Gun, Teardown components cap: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Back cap. This include the PCB. is weighted at 14g. Made from ABS plastic.
    • Bottom cap is weighted at 7g. Made from ABS plastic
    • Decoration parts. Non functional weighted at 3g.
  8. Mini Muscle Massage Gun, Internal components.: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Mini Muscle Massage Gun, Internal components.: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Mini Muscle Massage Gun, Internal components.: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Battery. Weighted at 72g. use to power the devic. 1800mAh lithium battery
    • Part connected to the device motor. Use as a connect to various massager head. Weighted at 19g.
    • Device motor. Weighted at 246g.
  9. Mini Muscle Massage Gun, Massage gun interchanagble head: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Red: Nylon: injection moulded
    • Blue: Rubber: injection moulded
    • Yellow: Eva foam:
  10. Mini Muscle Massage Gun, Teardown complete overview: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Device design is quite simple which encourage repairability.
    • most part found in the device and be easily replace by purchasing them online
    • 1800mAh high-quality rechargeable lithium battery can be easily replaced online.
    • 30W high-torque motor can also be replace. Purchased online. https://www.hisgifts.com.au/products/sta...
    • Any broken parts of the shell can easily be fixed with 3d printing.
    • most screw can also be found online
Nathasorn Pantratthanamongkol
crwdns2935283:003/21/24crwdne2935283:0
145 crwdns2915208:0crwdne2915208:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 57
crwdns2942667:0crwdne2942667:0 694
