Use this guide to replace the trigger for the Milwaukee Sawzall 6520-21. The trigger is used to operate the saw.
This guide has a prerequisite needed for completion. The tools required are a screwdriver handle and two bits:
- Torx 20
- 1.5mm Flathead
If the power cord has been removed, no tools are required, and takes 2 minutes to finish.
Unplug the Sawzall and Orient the right half-handle to face upwards.
With a T20 Torx screwdriver, remove the following screws:
7-18 x 1.125-inch Slt. Plastite T-20
8-16 x .625-inch Slt. Plastite T-20
Lift the handle off.
Remove the screw above the trigger.
8-16 x .625-inch
Take a 1.5mm flathead screwdriver and insert it into the pin lock above each of the wires:
Black wire: Insert it on the left side of the pin. Pull the wire while gently rotating it clockwise
Black wire: Insert it on the bottom side of the pin and gently rotate it counterclockwise
White wire: Insert it on the right of the pin and gently rotate it counterclockwise
Gently pull the yellow electrical wire.
The trigger paired with the motor housing wire requires two removals.
Gently remove both white wires.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
