If you need to replace the gearbox on your Milwaukee M18 2606-20 cordless power drill (the drill slips and loses torque to turn anything) see this guide on how to remove it. The gearbox is what controls the speed and torque of the drill. Removing some of the parts could require a bit of strength so keep this in mind.
Rotate the chuck counterclockwise to open the chuck jaws as far as possible.
Remove the 28 mm inner screw holding the chuck onto the drill using a Phillips #3 screwdriver.
Rotate the screw clockwise to loosen it.
Insert an Allen wrench into the chuck and tighten the chuck onto the wrench.
Rotate the Allen wrench counterclockwise to remove the chuck.
Using the T3 Torx screwdriver, remove the seven 18 mm screws from the handle area of the case.
Using the T3 Torx screwdriver, remove the two 21 mm screws from the top of the case.
Using the T3 Torx screwdriver, remove the four 20 mm screws from the front of the case.
Peel back the sticker at the bottom of the drill handle.
Open the case by sliding the opening tool all the way around the case to pry it apart.
Lift the gearbox slightly and pull away from the motor to remove it from the case .
Is T3 the correct size, for the casing screws? That seems a very small size. Disassembling mine (2606-20 F24D) I had to use a T10 for these screws.
