Milwaukee M18 2606-20 Gearbox Replacement
  1. Milwaukee M18 2606-20 Gearbox Replacement, Chuck: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Milwaukee M18 2606-20 Gearbox Replacement, Chuck: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Milwaukee M18 2606-20 Gearbox Replacement, Chuck: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate the chuck counterclockwise to open the chuck jaws as far as possible.
  2. Milwaukee M18 2606-20 Gearbox Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Milwaukee M18 2606-20 Gearbox Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 28 mm inner screw holding the chuck onto the drill using a Phillips #3 screwdriver.
    • Rotate the screw clockwise to loosen it.
    • The inner chuck screw is reverse threaded which is why it needs to be rotated clockwise.
  3. Milwaukee M18 2606-20 Gearbox Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Milwaukee M18 2606-20 Gearbox Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an Allen wrench into the chuck and tighten the chuck onto the wrench.
    • The Allen wrench will be used for leverage when removing the chuck.
    • When the chuck is tightened it could make a clicking sound. This is fine and is not causing any harm to the drill.
  4. Milwaukee M18 2606-20 Gearbox Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Milwaukee M18 2606-20 Gearbox Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Milwaukee M18 2606-20 Gearbox Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate the Allen wrench counterclockwise to remove the chuck.
  5. Milwaukee M18 2606-20 Gearbox Replacement, Gearbox: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Milwaukee M18 2606-20 Gearbox Replacement, Gearbox: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the T3 Torx screwdriver, remove the seven 18 mm screws from the handle area of the case.
    • Using the T3 Torx screwdriver, remove the two 21 mm screws from the top of the case.
  6. Milwaukee M18 2606-20 Gearbox Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Milwaukee M18 2606-20 Gearbox Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Milwaukee M18 2606-20 Gearbox Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the T3 Torx screwdriver, remove the four 20 mm screws from the front of the case.
  7. Milwaukee M18 2606-20 Gearbox Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Milwaukee M18 2606-20 Gearbox Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel back the sticker at the bottom of the drill handle.
  8. Milwaukee M18 2606-20 Gearbox Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Milwaukee M18 2606-20 Gearbox Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the case by sliding the opening tool all the way around the case to pry it apart.
  9. Milwaukee M18 2606-20 Gearbox Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Milwaukee M18 2606-20 Gearbox Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the gearbox slightly and pull away from the motor to remove it from the case .
Markus Eldridge
crwdns2935283:009/24/19crwdne2935283:0
922 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S1-G10, Watkins Fall 2019 crwdns2935289:0Embry-Riddle Aeronautical University, Team S1-G10, Watkins Fall 2019crwdne2935289:0
ERAU-WATKINS-F19S1G10
Is T3 the correct size, for the casing screws? That seems a very small size. Disassembling mine (2606-20 F24D) I had to use a T10 for these screws.
JFixIt - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 49
crwdns2942667:0crwdne2942667:0 4,718
