This guide will walk through the steps to replace the speed selector lever on the Milwaukee M12 2407-20.
Remove each of the seven 14mm Pan Hd. T-10 ST screws on one side of the housing assembly using the T10 screwdriver.
Remove metal clip located at the base of the drill, where the battery is to be inserted.
Remove the unit from the housing assembly and set the housing assembly aside.
Use a spudger to pry the broken speed selector lever off the assembly.
