Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch
  1. Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch, Forward/Reverse Switch: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch, Forward/Reverse Switch: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch, Forward/Reverse Switch: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Ensure that the device is unplugged from any power source to avoid electrical shock.
    • Flip the device and remove four 18mm screws using screws using a T20 Torx screwdriver.
    • Remove four 14mm screws using a T20 Torx screwdriver.
  2. Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four screws on each corner of the gear box assembly using a T20 Torx screwdriver.
    • Use a plastic pry bar slide out the gear box assembly away from the main body.
  3. Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Separate the top half of the clam shell from the tool.
    • Remove the gearbox assembly by sliding it forward.
    • Abrupt pulling may damage the motor brushes. Please remove it with caution.
    • The bushes may need to be compressed for easier removal of the motor.
  4. Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull up on the switch to remove it from the plastic mount.
    • There are six wires connected to the back of the switch.
    • Remove the black field wire winding from the switch.
  5. Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the blue lower brush wire (top right) from the connector.
    • Remove the black AC power wire from the switch.
    • The wires do not need to be removed in order, but doing so helps to minimize confusion.
  6. Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Milwaukee Impact Wrench 9070-20 Forward/Reverse Switch: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the switch vertically.
    • Remove the white upper brush wire from the connector.
    • Reconnect all wires and replace the new switch back into the plastic case mount.
    • Ensure that all wires are clear of the case so that they will not be damaged on reassembly.
Brandon Schneiberg
crwdns2935283:009/26/19crwdne2935283:0
255 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S13-G7, Lamothe Fall 2019 crwdns2935289:0Embry-Riddle Aeronautical University, Team S13-G7, Lamothe Fall 2019crwdne2935289:0
ERAU-LAMOTHE-F19S13G7
crwdns2942667:0crwdne2942667:0 1,082
