The following repair guide shows how to remove and replace the output shaft bearing in an Milwaukee Hex Impact Driver 2750-20.
Remove the five T9 15.5 mm screws.
Remove the single T9 19.5mm screw.
Remove the two T9 37mm screws.
Remove the drill casing to expose the drill's interior parts.
Once the interior is open locate the output shaft driver pictured at the left of the screen.
Lift the driver head and motor assembly directly out of the outer casing.
Pull the driver head away from the motor assembly, separating the two.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove the fan and the drive shaft assembly from the motor core assembly.
Using a pair of tweezers, remove the retaining ring.
Remove the old bearing and reinstall the new retaining clip.
