This guide will demonstrate how to replace the forward/reverse switch on the Milwaukee Hex Impact Driver 2656-20. The First Two steps will cover disassembly of the drill. The only tool required for this repair is a T-10 Torx Screwdriver. The repair is considered moderate in difficulty and will take approximately 15 minuets.
Squeeze the red buttons on the battery.
While squeezing the red buttons, slide the battery forward and out to remove it from the device.
Lay the impact driver on its side.
Remove eight 16 mm and a single 19 mm screws using the T10 Torx Screwdriver.
Separate the two halves by pulling up on the top half.
Lay the top half to the side.
Gently move the trigger assembly out of the way and remove the switch from the device.
