Milwaukee Hex Impact Driver 2656-20 Brush Block Assembly Replacement
  1. Milwaukee Hex Impact Driver 2656-20 Brush Block Assembly Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Milwaukee Hex Impact Driver 2656-20 Brush Block Assembly Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Squeeze the red buttons on the battery.
    • While squeezing the red buttons, slide the battery forward and out to remove it from the device.
  2. Milwaukee Hex Impact Driver 2656-20 Brush Block Assembly Replacement, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Milwaukee Hex Impact Driver 2656-20 Brush Block Assembly Replacement, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lay the impact driver on its side.
    • Remove eight 16 mm and a single 19 mm screws using the T10 Torx Screwdriver.
    • Separate the two halves by pulling up on the top half.
    • Make sure that the half with the screw heads Is facing up during this process. This will ensure that the components do not fall out.
    • Lay the top half to the side.
  3. Milwaukee Hex Impact Driver 2656-20 Brush Block Assembly Replacement, Brush Block Assembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Milwaukee Hex Impact Driver 2656-20 Brush Block Assembly Replacement, Brush Block Assembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 6mm screws on the back of the brush card assembly using the T10 Torx screwdriver.
  4. Milwaukee Hex Impact Driver 2656-20 Brush Block Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Milwaukee Hex Impact Driver 2656-20 Brush Block Assembly Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the motor and brush block assembly out of the drill housing.
  5. Milwaukee Hex Impact Driver 2656-20 Brush Block Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The gear case is easily separated from the electric motor by gently pulling the two pieces apart.
  6. Milwaukee Hex Impact Driver 2656-20 Brush Block Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Milwaukee Hex Impact Driver 2656-20 Brush Block Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the opening pick between one of the carbon brushes and the electric motor to help compress the spring.
    • While compressing the spring slide that section of the brush block assembly over the bearing.
    • The brush block assembly should easily slide over the bearing now, if it does not repeat the above process as needed for the other three carbon brushes.
BRYCE DICKERSON
crwdns2935283:009/05/19crwdne2935283:0
483 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S24-G2, McClure Fall 2019 crwdns2935289:0Embry-Riddle Aeronautical University, Team S24-G2, McClure Fall 2019crwdne2935289:0
ERAU-MCCLURE-F19S24G2
crwdns2942667:0crwdne2942667:0 1,545
