If your Milwaukee (6130-33) device is producing either loss of power or sound, then this replacement guide will provide you with step-by-step instructions in repairing your device. Necessary tools for the guide include a TR10 screwdriver and a set of pliers.
The carbon brush lock is responsible for maintaining the motor during usage. Worn or faulty brushes can damage both the interior casing and the brush casing. Regular maintenance and replacement of the brushes are important to maintain optimal performance and prevent damage.
Hold the device with the cord facing upwards and the bottom side facing down.
Remove the 4 mm TR20 Torx screws from the exterior case.
Remove the two 4 mm TR20 Torx screws to detach the clamp from the cord set.
Remove the two 3.5 mm TR10 Torx screws to access the wiring.
Remove both 3.5 mm TR10 Torx screws from the carbon brush locks.
Remove both springs by pulling outwards from the rotor.
Using a pair of pliers, squeeze the black cord.
Remove by pulling the black wire attached to the brush casing.
