Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement
  1. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement, Housing Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the ten 19mm T20 Torx screws shown in red.
  2. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the red Housing Assembly by lifting it up off of the tool.
  3. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement, Reduction Gear Assembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement, Reduction Gear Assembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 10mm T-10 Torx screws that attach the top brush holders to the motor housing.
    • Remove the two 10mm T-10 Torx screws that attach the bottom brush holders to the motor housing.
  4. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a metal spudger, pry off each brush holder.
  5. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 37mm T20 Torx screws shown in red.
  6. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the front portion of the tool out from the motor housing.
  7. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 11.5mm T10 Torx screws shown in red.
  8. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the 120V armature assembly out of the diaphragm assembly.
  9. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a metal spudger, pry the diaphgram assembly out of the gear case.
  10. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now that you have loosened the diaphragm, you can now pull it out of the gear case.
  11. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The diaphragm assembly will be lathered in grease. In order to move forward, you may want to give it a wipe down to remove any extra grease.
    • After removing some grease (if needed), remove the two 15mm T20 Torx screws shown in red.
  12. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Now pull the reduction gear assembly up and out of the diaphragm.
  13. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement, Diaphragm Assembly with Bushing: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement, Diaphragm Assembly with Bushing: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the metal piston from the diaphragm assembly.
  14. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a metal spudger, pry the o-ring off of the assembly.
Payton Parker
crwdns2935283:003/08/19crwdne2935283:0
534 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S1-G3, Botvin Spring 2019 crwdns2935289:0UMass Dartmouth, Team S1-G3, Botvin Spring 2019crwdne2935289:0
UMASSD-BOTVIN-S19S1G3
to reasemble .
Which is the correct position of the Shift knob assembly ?
Javier Martinez - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,093
