This guide is about how to replace a Control Switch for Milwaukee 2704-20 Drill. You will need to use the Milwaukee 2704-20 Disassembly Guide first in order to replace the control switch.
Remove the battery from the drill.
Remove the indicated screws (M3 x 16mm Pan Hd. ST T-10 Screws) with screwdriver.
Gently lift the cover off the drill. Be careful not to force it or damage any of the internal components.
Remove the control switch.
