Midland X-tra Talk Radio LXT118 Speaker Replacement
  1. Midland X-tra Talk Radio LXT118 Speaker Replacement, Batteries: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Midland X-tra Talk Radio LXT118 Speaker Replacement, Batteries: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • First, apply pressure with your thumb on the top of the battery cover.
    • Next, pull down on the cover until it begins to slide.
  2. Midland X-tra Talk Radio LXT118 Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Finally, once the cover is completely off, pry up the old batteries with your finger or a strong, skinny tool (i.e. spudger).
  3. Midland X-tra Talk Radio LXT118 Speaker Replacement, Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the six 8.0 millimeter long, #0 screws on the backside of the case using the Phillips #0 screwdriver.
  4. Midland X-tra Talk Radio LXT118 Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach back part of the case by gently lifting up.
  5. Midland X-tra Talk Radio LXT118 Speaker Replacement, Speaker: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the circuit board from the front part of the radio case.
    • Desolder the red and black speaker wires from the motherboard.
    • Be careful when soldering as the iron is very hot and will burn.
  6. Midland X-tra Talk Radio LXT118 Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Scrape off the glue on the outer lining of the speaker using the metal spudger.
  7. Midland X-tra Talk Radio LXT118 Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the speaker from the case using the metal spudger.
    • This should not take excessive force, so make sure all remaining glue is scraped off from the edges if it will not easily come out.
  8. Midland X-tra Talk Radio LXT118 Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The speaker is now disassembled!
  9. Midland X-tra Talk Radio LXT118 Speaker Replacement, Speaker: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Solder the new wires to the circuit board in the spots denoted by the two red circles.
  10. Midland X-tra Talk Radio LXT118 Speaker Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the speaker back inside the shell casing in the same way that it was originally placed.
    • Accurately use a polyurethane glue around the rim of the speaker to mount it firmly back inside the plastic casing.
James Tucker Dunn
crwdns2935283:001/18/13crwdne2935283:0
404 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 19-43, Regan Winter 2013 crwdns2935289:0Cal Poly, Team 19-43, Regan Winter 2013crwdne2935289:0
CPSU-REGAN-W13S19G43
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 902
