Midland GXT10x0VP4 GMRS radio Disassembly
  1. Midland GXT10x0VP4 GMRS radio Disassembly, The unit: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Midland GXT10x0VP4 GMRS radio Disassembly, The unit: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Front view
  2. Midland GXT10x0VP4 GMRS radio Disassembly, Remove battery(ies) to find screws to open: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • follow the instructions in the user manual
    • -remove belt clip (there is a small catch lever on the belt clip where it contacts clip mount point) *push outboard on the catch, to allow the clip to slide up and off
    • -pull battery compart cover latch down and let it swing on it's hinge
    • -lift bottom of batt. compartment cover up, and pull cover off radio
    • -pull Midland battery out (or AAA batteries if that's what you are using)
    • -there are 5 screws to remove
  3. Midland GXT10x0VP4 GMRS radio Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • split the cases by gently pulling apart
    • be careful of the 2 small extrusions that help to make the seal for the antenna
    • the batt. compartment latch and it's metal hinge pin are sandwiched in between 2 molded extrustions that form the hinge mount pount (between the 2 cases)
    • catch the latch and latch pin as you split the cases
    • BE CAREFUL - there is a pair of wires going to what looks like a small motor and some kind of spinning item
  4. Midland GXT10x0VP4 GMRS radio Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Midland GXT10x0VP4 GMRS radio Disassembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This is as far as I've gotten, as I want to research some more, and wait until I get a closer look at the radio in my workshop
    • - where are better antenna and other components sourced?
    • -how does one account for the water resistant seals when further dissassembling (seals around the On-Off/Volume knob, PTT switch and headphone/mic connectors)
    • -what is the spinning item/motor for? tone generation? some kind of EM field? (motor marked with yellow circle in 2nd pic)
See the other Midland portable GMRS guide here for some insight/context
David
crwdns2935283:001/17/21crwdne2935283:0
109 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 469
