crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Midea FC307B Rice Cookercrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Midea FC307B Rice Cooker Teardown, Initial dimensions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Midea FC307B Rice Cooker Teardown, Initial dimensions: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Midea FC307B Rice Cooker Teardown, Initial dimensions: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Midea FC307B Rice Cooker (prior to this teardown) in full working order, though the outlet cable had been lost.
    • Cooker weighs 3.2kg
    • Length: 304mm
    • Height: 218mm
    • Width 210mm
  2. Midea FC307B Rice Cooker Teardown, Removing the top: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Midea FC307B Rice Cooker Teardown, Removing the top: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Top filter pops off easily.
    • Top weighs 65g (both parts)
    • Length: 117mm
    • Width: 90mm
    • Height/Depth: 35mm
    • Top filter further breaks down into two more assemblies held together with a hook hinge and a latch
  3. Midea FC307B Rice Cooker Teardown, Top latch disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Midea FC307B Rice Cooker Teardown, Top latch disassembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Midea FC307B Rice Cooker Teardown, Top latch disassembly: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Latch mechanism is held to the part with a single Phillips head m2 screw
    • The 4 parts sit together (as shown) to form the latch mechanism.
    • Note: the large slot in the white button component, that allows it to slide past the screw which intersects it. The red line illustrated how the screw intersects it.
    • All component's are made from ABS plastic with exception of the stainless-steel screw, and steel spring.
  4. Midea FC307B Rice Cooker Teardown, Top teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Midea FC307B Rice Cooker Teardown, Top teardown: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Midea FC307B Rice Cooker Teardown, Top teardown: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The top of the filter had three parts that came off relatively easily. A neoprene gasket that could just be pulled off, the main injection moulded ABS plastic body. And a stamped stainless steel element.
    • The stainless-steel element had tabs that were folded around the main plastic body. It could easily be removed using a flat wedge screwdriver to flip them up.
    • These tabs folded into gaps on the underside of the plastic body.
    • Length: 117mm
    • Width: 90mm
    • Height/Depth: 12mm
  5. Midea FC307B Rice Cooker Teardown, Unscrewing the bottom: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Midea FC307B Rice Cooker Teardown, Unscrewing the bottom: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Midea FC307B Rice Cooker Teardown, Unscrewing the bottom: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Bottom component made from grey ABS injection moulded plastic.
    • Bottom is held to the upper body of the cooker using 4 long Phillips head m3 screws which had to be accessed with a long screwdriver.
    • Bottom was further supported by 2 shorter m3 screws that also held neoprene stoppers on the underside of the cooker. I am not sure what is the purpose of these neoprene stoppers, possibly heat insulation?
    • Length: 317mm
    • Width: 245mm
    • Depth/Height: 75mm
  6. Midea FC307B Rice Cooker Teardown, Screws from the bottom: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Midea FC307B Rice Cooker Teardown, Screws from the bottom: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • All the components I removed whilst unscrewing the bottom
    • White injection moulded ABS plastic housing for the outlet cable.
    • Neoprene white stoppers, held on using m3 screws. Not sure what purpose they have.
    • Neoprene feet, prevent the cooker from falling off a surface by creating friction with the surface.
    • 13mm long m3 Philips head screws, holds the bottom of the rice cooker to the upper
  7. Midea FC307B Rice Cooker Teardown, Inner Workings - first glance: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Midea FC307B Rice Cooker Teardown, Inner Workings - first glance: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Removing the base by removing the screws, the inner workings of the cooker are exposed.
    • PCB circuit board - controls the cooker
    • Power outlet
    • Cooking/heating bowl - heats the removable aluminium bowl (second picture)
    • SEE STEP 18 FOR BOWL DETAILS
  8. Midea FC307B Rice Cooker Teardown, Circuit board frame & wire holders: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Midea FC307B Rice Cooker Teardown, Circuit board frame & wire holders: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Midea FC307B Rice Cooker Teardown, Circuit board frame & wire holders: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Mechanical buttons and circuit board are connected to a purple ABS injection moulded plastic frame
    • Frame is held to the main body of the cooker using 3 hard to access m2 Phillips head screws (here I have removed them)
    • Special hooks on the plastic frame for collecting and holding all the wires
  9. Midea FC307B Rice Cooker Teardown, Back cover: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Midea FC307B Rice Cooker Teardown, Back cover: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Midea FC307B Rice Cooker Teardown, Back cover: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Back cover had two purposes: (1) to prevent the handle from being able to line up with its slots (see next step) and (2) to cover the torsion springs that actuate the lid
    • Width: 32mm
    • Height: 77mm
    • Length: 130mm
  10. Midea FC307B Rice Cooker Teardown, Handle Removale: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Midea FC307B Rice Cooker Teardown, Handle Removale: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Midea FC307B Rice Cooker Teardown, Handle Removale: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After removing the bottom was able to see inside and see where the handle poked through onto the inside of the corner. Noticed the end of the handle had a nodule. Realised that the only way to remove the handle was to line up the nodule slot in the side.
    • Nodule slot on the handle, and on the side of the cooker
    • Weight of handle: 81g
    • Handle made from injection moulded ABS plastic. The mould notable has two halves indicated by the seam that runs along the inside of the handle
    • Height: 188mm
    • Width: 22mm
    • Length: 245mm
    • To remove handle and line it up with eh slots, the back cover had to be removed (previous step)
  11. Midea FC307B Rice Cooker Teardown, Lid Interior: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Removing the lid interior
    • button latches hold the lid interior inside of the lid - see arrows
  12. Midea FC307B Rice Cooker Teardown, Unriviting the lid interior: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Midea FC307B Rice Cooker Teardown, Unriviting the lid interior: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Midea FC307B Rice Cooker Teardown, Unriviting the lid interior: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lid interior was held together using aluminium pop rivets - had to remove them by drilling the head off and using a punch to knock the rivets out.
    • Stamped aluminium plate
    • Outer neoprene gasket - injection moulded
    • Inner neoprene gasket - injection moulded
    • Main body housing - ABS plastic injection moulded
    • Steel springs
    • Riveting surface? ABS plastic injection moulded
    • Latches - ABS plastic injection moulded
  13. Midea FC307B Rice Cooker Teardown, Dismantling inner lid: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Midea FC307B Rice Cooker Teardown, Dismantling inner lid: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Midea FC307B Rice Cooker Teardown, Dismantling inner lid: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove the ABS plastic clips I had to use a nail/thin screwdriver to push the clip ends inside the housing
    • Aluminium plate (like other parts of this cooker) held on by crimped tabs - had to uncrimp them using a thin screwdriver
  14. Midea FC307B Rice Cooker Teardown, Removing inner plate: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Midea FC307B Rice Cooker Teardown, Removing inner plate: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Midea FC307B Rice Cooker Teardown, Removing inner plate: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Inside the lid there was a secondary stamped aluminium Pannel. It was held onto the lid curiously by 13 individual Phillips head screws
    • 12mm m3 Phillips head screw - stainless steel
    • 9mm m2 Phillips head screw - stainless steel
    • 12mm m3 Phillips head screw - nickel plated steel
    • Why 3 different types of screw with two different types of material used?
    • Brass nut for m3 screw/bolt
    • m3 washer for electronic component?
  15. Midea FC307B Rice Cooker Teardown, Removing foil: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the interior aluminium plate was removed, there was a thin layer of aluminium foil held on using a thermal resistant adhesive. I pulled the foil off revealing a heat sensor
    • Heat sensor
    • Adhesive
    • Fuse?
  16. Midea FC307B Rice Cooker Teardown, Lid: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Midea FC307B Rice Cooker Teardown, Lid: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Midea FC307B Rice Cooker Teardown, Lid: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lid was connected by wires/leads that were adhered to the inside of the lid. Had to cut the wires with a wire cutter to be able to remove the lid.
    • Length: 270mm
    • Width: 232mm
    • height/Depth: 45mm
  17. Midea FC307B Rice Cooker Teardown, Lid Gasaket: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Midea FC307B Rice Cooker Teardown, Lid Gasaket: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Inside the lid was a neoprene gasket - see purple for indication of where it went
    • Diameter of gasket:50mm
    • Hehgiht:15mm
  18. Midea FC307B Rice Cooker Teardown, Bowl: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Midea FC307B Rice Cooker Teardown, Bowl: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Spin moulded anodised aluminium bowl
    • PTFE nonstick coating on the inside
    • Height: 110mm
    • Diameter: 206mm
OwainLloyd
crwdns2935283:008/14/24crwdne2935283:0
277 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 346
