Midas Pro 2C CMOS Battery Replacement
  1. Midas Pro 2C CMOS Battery Replacement, CMOS Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the Midas Pro 2C off and ensure your work area is clear.
  2. Midas Pro 2C CMOS Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Midas Pro 2C CMOS Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the switches connected to the two power supply units (PSU) to the off position.
  3. Midas Pro 2C CMOS Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Midas Pro 2C CMOS Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully remove the cords from both PSU’s.
  4. Midas Pro 2C CMOS Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Midas Pro 2C CMOS Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip both PSU switches back to the on position.
    • Leave the PSUs on for 30 seconds to ensure that the power is fully discharged from the units.
  5. Midas Pro 2C CMOS Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Midas Pro 2C CMOS Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the twelve 10 mm T10 Torx screws from the cover of the console.
  6. Midas Pro 2C CMOS Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Midas Pro 2C CMOS Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Set a cloth down over the top half of the console to protect it from damage in the following steps.
  7. Midas Pro 2C CMOS Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Midas Pro 2C CMOS Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Midas Pro 2C CMOS Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a metal spudger to carefully pry the control panel from the console.
    • Work your way around the perimeter with the spudger to undo the clips securing the control panel and remove it from the console.
    • Keep your hand in constant contact with the panel, dropping it may damage the unit.
    • Lift the panel very slowly and ensure none of the fader's cables get stuck on the inside edge of the console.
  8. Midas Pro 2C CMOS Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Midas Pro 2C CMOS Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Midas Pro 2C CMOS Battery Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the ribbon cable from the control panel by moving the two black latches outward, away from the cable.
    • Pull out the cable.
    • Lay the panel against the material you used to cover the top section of board but make sure panel doesn't slide or fall.
  9. Midas Pro 2C CMOS Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Midas Pro 2C CMOS Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Midas Pro 2C CMOS Battery Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Identify the CMOS battery to the right of the circuit board.
    • To remove the battery, push the metal tab out of the way, and use the tweezers to pull out the old battery.
    • Check with your local battery recycling guidelines to discard the old battery.
  10. Midas Pro 2C CMOS Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Midas Pro 2C CMOS Battery Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To insert the new 2032 battery, push the tab back and slide in the new battery.
    • Make sure the new battery is oriented the same way as the old battery.
  11. Midas Pro 2C CMOS Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Midas Pro 2C CMOS Battery Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Midas Pro 2C CMOS Battery Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reattach the ribbon cable to the control panel.
    • Secure the locking latches by pushing them towards the cable.
    • Carefully lower the panel back onto the console, make sure the wires aren’t being pinched as you set the panel back down.
    • Replace the screws to attach the control panel to the the console.
  12. Midas Pro 2C CMOS Battery Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Midas Pro 2C CMOS Battery Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Midas Pro 2C CMOS Battery Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure both PSUs are off, then plug the UPC cables back in.
    • Turn both the PSU units on, this should switch the console on.
    • As the console turns on and boots up, press F2 frequently until the console enters into the set-up menu.
  13. Midas Pro 2C CMOS Battery Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Read directions on the console to navigate through the set up menu.
    • Change the date and time they are correct.
  14. Midas Pro 2C CMOS Battery Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Midas Pro 2C CMOS Battery Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Midas Pro 2C CMOS Battery Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Click down with arrow key to the "excluded from boot order list".
    • Press the X key while “ATP Compact Flash” is highlighted in white.
    • This adds the operating system back to the order.
    • Navigate to the exit.
    • Arrow key down to save and exit.
    • Confirm changes by selecting yes.
  15. Midas Pro 2C CMOS Battery Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The console should reboot back into the operating system.
    • Ensure the console date and time is set correctly and if not repeat steps 12 through 14.
crwdns2935229:05crwdne2935229:0
David Braese
crwdns2935283:002/10/23crwdne2935283:0
331 crwdns2915208:0crwdne2915208:0
University of Memphis, Team 2-69, Cameron Spring 2023 crwdns2935289:0University of Memphis, Team 2-69, Cameron Spring 2023crwdne2935289:0
UM-CAMERON-S23S2G69
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 37
crwdns2936753:030crwdne2936753:0 247
crwdns2942667:0crwdne2942667:0 5,345
