This is a guide to replace the motherboard in the device. Make sure to follow all the steps correctly and handle with care.
Using a J00 Phillips-head screwdriver, remove the two screws located at the bottom of the device.
Use the plastic opening tool to pry off the white back-plate of the device.
Using a +00 Phillips head screwdriver, remove the screws securing the motherboard to the device housing.
Desolder the two black and red wires connected to the motherboard.
Unclip and remove the ribbon cables attached to the motherboard.
Carefully lift and remove the motherboard from the device housing.
