Microtek ScanMaker 5900 Stepper Motor Replacement
crwdns2869540:0crwdne2869540:0: 2.2K
0
10
51
2,214
crwdns2959984:0crwdne2959984:0: 1
crwdns2959972:01crwdne2959972:0
crwdns2959986:0crwdne2959986:0: 2
crwdns2959982:02crwdne2959982:0
crwdns2955944:0crwdne2955944:0: 15 - 20 crwdns2931279:0crwdne2931279:0
This guide will show you how to replace the scanners stepper motor.
    1. Microtek ScanMaker 5900 Stepper Motor Replacement, Remove serial port connection: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microtek ScanMaker 5900 Stepper Motor Replacement, Remove serial port connection: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microtek ScanMaker 5900 Stepper Motor Replacement, Remove serial port connection: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Loosen the screws on the serial port by turning them counter clockwise by hand.
      • After loosening the screws, pull the serial port out.
    2. Microtek ScanMaker 5900 Stepper Motor Replacement, Remove Lid: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microtek ScanMaker 5900 Stepper Motor Replacement, Remove Lid: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microtek ScanMaker 5900 Stepper Motor Replacement, Remove Lid: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lift lid to its vertical position.
      • Pull lid straight up to remove it from the scanner.
    1. Microtek ScanMaker 5900 Stepper Motor Replacement, Detach plastic latches: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microtek ScanMaker 5900 Stepper Motor Replacement, Detach plastic latches: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microtek ScanMaker 5900 Stepper Motor Replacement, Detach plastic latches: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Push the plastic opening tools into the crack between the top and the bottom of the chassis.
    2. Microtek ScanMaker 5900 Stepper Motor Replacement, Continue latch detachment: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microtek ScanMaker 5900 Stepper Motor Replacement, Continue latch detachment: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microtek ScanMaker 5900 Stepper Motor Replacement, Continue latch detachment: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • After placing one plastic opening tool into the slit, slide other plastic opening tools along the slit to detach the top from the bottom of the chassis.
      • Go all the way along the chassis until you can lift the upper lid.
    3. Microtek ScanMaker 5900 Stepper Motor Replacement, Fully remove the upper lid: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microtek ScanMaker 5900 Stepper Motor Replacement, Fully remove the upper lid: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microtek ScanMaker 5900 Stepper Motor Replacement, Fully remove the upper lid: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Do not fully remove the lid until you remove the ribbon cable attached to the front of the upper lid.
      • Do this by grabbing the upper lid from the sides and rotating it ninety degrees so it is perpendicular to the bottom lid.
      • Grab the ribbon cable and gently pull it out of its slot with your fingers.
      • The upper lid can now safely be removed from the bottom lid.
    1. Microtek ScanMaker 5900 Stepper Motor Replacement, Stepper Motor: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microtek ScanMaker 5900 Stepper Motor Replacement, Stepper Motor: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Locate the stepper motor. With the front of the scanner facing you, the motor is located at the top left.
      • Disconnect the white connector from the vertical standing circuit board.
    2. Microtek ScanMaker 5900 Stepper Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microtek ScanMaker 5900 Stepper Motor Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microtek ScanMaker 5900 Stepper Motor Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using a #2 Philips Screwdriver, unscrew the two 7.7mm screws holding the stepper motor in place.
      • The stepper motor will become loose, but not completely free.
    3. Microtek ScanMaker 5900 Stepper Motor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microtek ScanMaker 5900 Stepper Motor Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microtek ScanMaker 5900 Stepper Motor Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using tweezers gently remove the tread from the black gear on the stepper motor.
      • The stepper motor will become completely free.
Steven Shaginyan
crwdns2935283:010/12/11crwdne2935283:0
39 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-9, Regan Fall 2011 crwdns2935289:0Cal Poly, Team 6-9, Regan Fall 2011crwdne2935289:0
CPSU-REGAN-F11S6G9
crwdns2935297:0132crwdne2935297:0
crwdns2936753:030crwdne2936753:0 51
crwdns2959996:0crwdne2959996:0 2,214
