crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Microsoft Wireless Mobile Mouse 4000crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Microsoft Wireless Mobile Mouse 4000 Teardown, Remove Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Undo the bottom battery clip and remove any AA battery within.
    • Remove the USB receiver if stored
    • The device should look as pictured.
  2. Microsoft Wireless Mobile Mouse 4000 Teardown, Remove Bottom Rubber Traction: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Wireless Mobile Mouse 4000 Teardown, Remove Bottom Rubber Traction: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Wireless Mobile Mouse 4000 Teardown, Remove Bottom Rubber Traction: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using your prying device, pick at the corner of the lower rubber traction pad on the bottom of the device.
    • Pull this traction pad off to reveal the screw underneath.
    • Unscrew this middle screw using the small 3mm phillips screwdriver.
    • Carefully disconnect the top click pads.
    • Note: Moving each towards its corresponding outer edge makes this easier
  3. Microsoft Wireless Mobile Mouse 4000 Teardown, Undo back clip piece.: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Wireless Mobile Mouse 4000 Teardown, Undo back clip piece.: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the two screws on the top front of the device.
    • Using prying tool undo the back clip piece shown.
  4. Microsoft Wireless Mobile Mouse 4000 Teardown, Separate top and bottom halves: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Wireless Mobile Mouse 4000 Teardown, Separate top and bottom halves: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Wireless Mobile Mouse 4000 Teardown, Separate top and bottom halves: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove two screws in the top back of the mouse.
    • Pry the top and bottom halves apart.
    • This takes a little prying between the outer pieces, which are connected to the top half, and the plastic bottom half.
    • The mouse should now have two separate parts as shown.
  5. Microsoft Wireless Mobile Mouse 4000 Teardown, Remove click wheel: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Wireless Mobile Mouse 4000 Teardown, Remove click wheel: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using prying tool press against the bottom of each side of the click wheel apparatus to cause it to snap out of place.
    • The end of the click wheel closest to the middle of the mouse is more difficult to remove and requires getting the prying tool down the gap to reach the spot where it is clipped in.
  6. Microsoft Wireless Mobile Mouse 4000 Teardown, Separate PCB from bottom plastic guard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Wireless Mobile Mouse 4000 Teardown, Separate PCB from bottom plastic guard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Wireless Mobile Mouse 4000 Teardown, Separate PCB from bottom plastic guard: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove 2 Screws from either side of the click wheel on the lower tier of the PCB.
    • Remove the 3 screws from the top tier of the PCB.
    • Do not separate the PCB from the plastic backing too fast. There is a separate small PCB screwed into the plastic backing which is connected to the main PCB with 2 wires.
    • Remove the screw holding the small PCB to the plastic backing
  7. Microsoft Wireless Mobile Mouse 4000 Teardown, PCB can now be removed: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Wireless Mobile Mouse 4000 Teardown, PCB can now be removed: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Parts of the PCB are listed below and correspond to the colored circles on the pictures
    • LED tracking apparatus
    • Battery power receiving mechanism
    • Left and Right Click Buttons
    • Click Wheel Button
    • Scroll wheel sensing apparatus
    • Programmable Button
Austin Fox
crwdns2935283:004/10/12crwdne2935283:0
118 crwdns2915208:0crwdne2915208:0
crwdns2947412:014crwdne2947412:0
Thank you for this guide. It helped me successfully repair my mouse!
Justin Hren - crwdns2934203:0crwdne2934203:0
Thanks a lot, I was able to replace the mouse wheel !
Niek - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 33
crwdns2936753:030crwdne2936753:0 129
crwdns2942667:0crwdne2942667:0 29,328
