Microsoft Surface Pro 7+ SSD Replacement
  1. Microsoft Surface Pro 7+ SSD Replacement, Before you begin: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before starting your repair, unplug all cables and fully shut down your Surface Pro.
  2. Microsoft Surface Pro 7+ SSD Replacement, Open the kickstand: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 7+ SSD Replacement, Open the kickstand: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the kickstand to about 90 degrees.
  3. Microsoft Surface Pro 7+ SSD Replacement, Remove the SSD door: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 7+ SSD Replacement, Remove the SSD door: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 7+ SSD Replacement, Remove the SSD door: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Firmly press a SIM eject tool into the small hole in the corner of the SSD door until it pops up.
    • Alternatively, you can also use a small, straightened paper clip.
    • Remove the SSD door.
  4. Microsoft Surface Pro 7+ SSD Replacement, Remove the SSD screw: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 7+ SSD Replacement, Remove the SSD screw: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Removing the SSD also functions as a battery disconnect and should be done before all major repairs.
    • Use a Torx Plus 3IP screwdriver to remove the 2.2 mm‑long screw securing the SSD.
  5. Microsoft Surface Pro 7+ SSD Replacement, Remove the SSD: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 7+ SSD Replacement, Remove the SSD: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Don't pull up at a sharp angle, or you may damage the SSD and its socket.
    • Use your fingers to pull the SSD out of its socket at a shallow angle.
To reassemble your device, follow these instructions in reverse order. Once your laptop is reassembled, follow Microsoft's post SSD replacement guide.
Spencer Day
crwdns2935283:009/14/22crwdne2935283:0
187,545 crwdns2915208:0crwdne2915208:0
crwdns2935297:01,187crwdne2935297:0
crwdns2936753:07crwdne2936753:0 37
crwdns2936753:030crwdne2936753:0 37
crwdns2942667:0crwdne2942667:0 54
