Microsoft Surface Pro 5 Camera Tie Bar Replacement
  1. Microsoft Surface Pro 5 Camera Tie Bar Replacement, Disconnect the display board: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Camera Tie Bar Replacement, Disconnect the display board: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Camera Tie Bar Replacement, Disconnect the display board: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to flip up the small locking flaps on the display cable ZIF connectors.
  2. Microsoft Surface Pro 5 Camera Tie Bar Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Camera Tie Bar Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Camera Tie Bar Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers to slide the display cables straight out of their sockets on the display board.
  3. Microsoft Surface Pro 5 Camera Tie Bar Replacement, Remove the display board: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Camera Tie Bar Replacement, Remove the display board: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Camera Tie Bar Replacement, Remove the display board: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide an opening pick under the display board to separate the adhesive holding it onto the back of the screen.
  4. Microsoft Surface Pro 5 Camera Tie Bar Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Tesa 61395 Tape
    $5.99
    • Remove the display board.
    • During reassembly, use a strong double-sided tape or a precut adhesive card to secure the display board. Clean off the old adhesive before applying new adhesive.
    • To ensure correct positioning, plug in both display connectors before adhering the board to the display.
  5. Microsoft Surface Pro 5 Camera Tie Bar Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Only the screen remains.
  6. Microsoft Surface Pro 5 Camera Tie Bar Replacement, Remove the heat sink shield: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 5 Camera Tie Bar Replacement, Remove the heat sink shield: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert one point of a pair of pointed tweezers into a gap in the corner of the EMI shield covering the heat sink.
    • Use the tweezers to pry the EMI shield away from the motherboard as much as you can without bending it. Do not remove it yet.
    • Try not to deform the shield too much—you will need to reinstall it during reassembly.
    • Take care not to puncture the battery with the tweezers while working on this shield.
  7. Microsoft Surface Pro 5 Camera Tie Bar Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Camera Tie Bar Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Camera Tie Bar Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the last step for each corner of the EMI shield covering the heat sink.
  8. Microsoft Surface Pro 5 Camera Tie Bar Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the heat sink shield.
  9. Microsoft Surface Pro 5 Camera Tie Bar Replacement, Remove the heat sink: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 5 Camera Tie Bar Replacement, Remove the heat sink: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the nine Torx screws securing the heat sink:
    • Five 2.6 mm-long T3 screws
    • Four 3.3 mm-long T5 screws
    • During reassembly, tighten the heat sink screws in the following criss-cross pattern, one turn at a time, until they're tight:
    • Screw 1
    • Screw 2
    • Screw 3
    • Screw 4
  10. Microsoft Surface Pro 5 Camera Tie Bar Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Camera Tie Bar Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Camera Tie Bar Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  11. Microsoft Surface Pro 5 Camera Tie Bar Replacement, Camera Tie Bar: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the Torx T5 x 6mm screw connecting the black tie bar to the power button/volume control/speaker assembly.
  12. Microsoft Surface Pro 5 Camera Tie Bar Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the remaining three Torx T5 x 4.5mm screws holding down the camera tie bar.
  13. Microsoft Surface Pro 5 Camera Tie Bar Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the small ribbon cable connecting the camera tie bar to the motherboard by pulling up with tweezers.
  14. Microsoft Surface Pro 5 Camera Tie Bar Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the camera tie bar off of the device.
Paul Manzer
crwdns2935283:010/02/17crwdne2935283:0
758 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S15-G3, Livingston Fall 2017 crwdns2935289:0Cal Poly, Team S15-G3, Livingston Fall 2017crwdne2935289:0
CPSU-LIVINGSTON-F17S15G3
crwdns2935297:017crwdne2935297:0
Do you really need to remove the heat sink shield and the heat sink to disconnect the tie bar small ribbon cable ?
Tamanaco Francisquez - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,031
