Microsoft Surface Pro 2 Camera Replacement
    1. Microsoft Surface Pro 2 Camera Replacement, LCD Display: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 2 Camera Replacement, LCD Display: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • To avoid electrical shocks, unplug and turn off your Surface Pro 2 before proceeding.
    2. Microsoft Surface Pro 2 Camera Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Avoid any skin or eye contact with the heating pad or heating gun because they may cause bodily harm.
      • Using a heating pad or heating gun, heat the edges of the screen to soften the glue. This area extends roughly one inch from the edge of the device.
      • The glue is under the darker border of the device display.
    3. Microsoft Surface Pro 2 Camera Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using a plastic opening tool and a suction cup as needed for leverage, gently insert one edge of the opening tool under the corner of the screen.
      • If the tool does not easily slide under the screen, return to heating before proceeding.
      • Slowly work the tool around the entire edge of the screen.
    4. Microsoft Surface Pro 2 Camera Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 2 Camera Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 2 Camera Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Detach the orange cables that connect the screen to the motherboard by pulling on the small tabs. Using the nylon spudger, release these cables.
      • Please note the third small connector in red.
      • Allow the glue to cool before letting it come into contact with any other surface.
    1. Microsoft Surface Pro 2 Camera Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 2 Camera Replacement, Motherboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 2 Camera Replacement, Motherboard: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Make sure that the front-facing camera is completely disconnected, and then remove the plastic bracket.
      • Remove the 22 screws on the bezel.
      • Remove the left and right brackets; the left has 16 screws and the right has 15 screws.
      • The three different torx screws used are T3, T4, and T5.
    2. Microsoft Surface Pro 2 Camera Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 2 Camera Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 2 Camera Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Once the brackets are removed, set them aside.
      • The motherboard itself also has screws.
      • Remove the 25 screws of varying sizes that attach the motherboard to the back plate.
      • View the attached photo of a screw diagram to help keep track of your screws.
    3. Microsoft Surface Pro 2 Camera Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 2 Camera Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 2 Camera Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • You have now completely removed the motherboard, and it should look like the pictures shown.
      • Be sure to be cautious with all the connections with the cables on the motherboard.
    1. Microsoft Surface Pro 2 Camera Replacement, Camera: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the ribbon that the spudger is touching in the picture.
      • Remove the front-facing camera.
    2. Microsoft Surface Pro 2 Camera Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    3. Microsoft Surface Pro 2 Camera Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 2 Camera Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
abdulhameeda
crwdns2935283:009/07/16crwdne2935283:0
108 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 6-2, Remmell Fall 2016 crwdns2935289:0USF Tampa, Team 6-2, Remmell Fall 2016crwdne2935289:0
USFT-REMMELL-F16S6G2
crwdns2935297:048crwdne2935297:0
crwdns2936753:030crwdne2936753:0 56
crwdns2942667:0crwdne2942667:0 1,419
