Follow this guide to replace a damaged lower case (aka bottom cover) on your Microsoft Surface Laptop 7 (13.8‑inch).
Unplug all cables and fully shut down your laptop.
Close your laptop and lay it down so the rubber feet are facing up.
Gently slide one arm of your angled tweezers into the recess near the upper right edge of one of the feet.
Use your tweezers to pry up and remove the foot.
Repeat the process to remove the remaining feet.
crwdns2935267:0crwdne2935267:0FixMat$36.95
Use a Torx Plus 5IP screwdriver to remove the four 4.5 mm‑long screws (with washers) securing the lower case.
Insert the tip of an opening pick under the top edge of the lower case, about an inch (2.5 cm) to the left or right of the Microsoft logo.
Twist the pick to lift the lower case enough that you can grip it with your hand.
Lift the lower case and remove it.
where can i purchase 4 spare screws for the bottom of this laptop?
I would like to know the same thing. I'v lost one of my screws off my Surface laptop 7. Does anyone know what size screw is needed?
