Microsoft Surface Headphones Speaker Replacement
  1. Microsoft Surface Headphones Speaker Replacement, Ear Cushion: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Firmly grasp the ear cushions, and rotate them counterclockwise about 45 degrees, or until you hear a "click."
    • Be careful not to use excessive force during rotation.
  2. Microsoft Surface Headphones Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the ear cushions off the speaker housings.
  3. Microsoft Surface Headphones Speaker Replacement, Speaker: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Headphones Speaker Replacement, Speaker: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the six 2.6mm screws with a Phillips #00 screwdriver, and gently lift the speaker housings away.
    • If only one of the speakers is malfunctioning, only remove the screws on the affected side, and leave the functional speaker intact.
  4. Microsoft Surface Headphones Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Headphones Speaker Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pry the speaker housing away from the chassis with a spudger.
  5. Microsoft Surface Headphones Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder the speaker's motherboard connections.
    • Desoldering and soldering are delicate procedures, and there is a potential for device damage.
Ethan Haight
crwdns2935283:002/08/22crwdne2935283:0
879 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-3, Virtue Spring 2022 crwdns2935289:0Western Carolina University, Team 1-3, Virtue Spring 2022crwdne2935289:0
WCU-VIRTUE-S22S1G3
crwdns2947412:09crwdne2947412:0
How can I get my turtle Beach to pair
Miguel Garcia - crwdns2934203:0crwdne2934203:0
How do I remove the speaker from the plastic housing? Is it glued in place? I desoldered the speaker unit and now I am trying to take out speaker from its housing.
Stephen Hyland - crwdns2934203:0crwdne2934203:0
I would also like to know this! replacing the speaker requires the plastic housing to be opened. I tried heating the housing with a hair dryer but no result....
fixer8888 -
I cut it in half down the side. Very long a tedious process. also makes it hard to get a tight seal for reassembly but with a little more patience than I had and a clamp to glue the pieces together could probably get a nice finish. I have a gap which causes a little weirdness for the ANC especially with wind.
joshray -
@joshray how did you cut the plastic open exactly? Having the same issue and I also thought about cutting open the plastic housing to get to the speaker but am unsure how to do this exactly.
fixer8888 -
@fixer8888 I used a serrated knife and its was not the right tool, I would recommend maybe a hacksaw where the blade is much thinner, so you'll have a better chance of reassembling after replacing the speaker. Don't cut straight through just go around the edges and only as deep as the screw mounting holes
joshray -
Where do you get replacement speaker
marilyn - crwdns2934203:0crwdne2934203:0
For the Surface 2 it's T6H screws, otherwise this is correct to dismantle and put them together again.
(Unfortunately I could not find any problem I could solve. My left earpiece remains silent)
Anders Hedberg - crwdns2934203:0crwdne2934203:0
hey im having the same issue, how do you know your speaker is g2g? did you test its impedance with a multimeter?
Tony Tran -
crwdns2936753:030crwdne2936753:0 47
crwdns2942667:0crwdne2942667:0 2,371
