This guide will show you how to remove and replace the touch screen in the Microsoft Lumia 640 XL.
Place left palm on screen and right palm on the back.
Press down with fingertips and pull to separate the back from the screen.
Lift the battery away from the phone with the flat side of a spudger.
Remove all ten T3, 4.09 mm screws.
Lift mid-frame assembly from phone with flat side of a spudger.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Lift and peel connector away from phone using tweezers.
Remove all three T3, 2.66 mm screws.
Lift off connector with tweezers.
Lift motherboard off with tweezers and pull away with fingers.
Remove the screen from the device.
