Microsoft Lumia 535
RM-1090 / RM-1091/ RM-1089 / RM-1092
How to disassemble the phone and replace broken, smashed Display or Touch Screen Glass Digitizer.
!!!There are different versions touch screens:
• CT2S1973FPC-A1-E
• CT2C1607FPC-A1-E
The version is printed on the flex cable.
crwdns2936621:0crwdne2936621:0
Turn off the phone.
Remove the battery and any SIM and memory cards.
With a screwdriver Torx T4 remove the 9x screws.
With a plastic opening tool separate the back cover from the middle frame.
Disconnect:
Touch screen flex cable
LCD Display flex cable
Charging Dock board flex cable - remove the foam and tape, then flip up the black lock before easing out the flex.
Coaxial antena cable - take your time here, be sure to pull the metal connector and not the cable or you risk pulling the cable from the connector.
Remove the 2x Torx T4 screws.
Remove the display flex cable rubber.
Put scotch tape on glass to prevent it from shattering.
Use a hair dryer or heat gun and warm the glass to make adhesive soft.
Use a cutter or other tool with a sharp edge and start the separating from the bottom side. When you make enough room, continue the operation with a plastic tool.
Using a plastic tool, carefully remove the display.
Clean the frame from the remainders of the old adhesive.
Install back the display.
Put adhesive tape 2mm on the digitizer.
Install the touch screen and start with the reassembling.
That's all.
Did you do it successfully?
crwdns2935229:050crwdne2935229:0
crwdns2947412:019crwdne2947412:0
hi
cane you tell me price of out glass of lumia 535 duol sim please ?!
2mm adhesive tape means thickness
Also does touch come out if we put adhesive tape.
I want to join in your team
Hi,How to know which the versions touch screens my phone is Lumia 535 RM-1089 , please?
