Microsoft Lumia 535 Logic board Replacement
crwdns2936621:0crwdne2936621:0
  1. Microsoft Lumia 535 Logic board Replacement, Back Cover / Rear Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Lumia 535 Logic board Replacement, Back Cover / Rear Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn off the phone.
    • Remove the battery and any SIM and memory cards.
  2. Microsoft Lumia 535 Logic board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Lumia 535 Logic board Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With a screwdriver Torx T4 remove the 9x screws.
  3. Microsoft Lumia 535 Logic board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Lumia 535 Logic board Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Lumia 535 Logic board Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With a plastic opening tool separate the back cover from the middle frame.
  4. Microsoft Lumia 535 Logic board Replacement, Logic board: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Lumia 535 Logic board Replacement, Logic board: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Lumia 535 Logic board Replacement, Logic board: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect:
    • Touch screen flex cable
    • LCD Display flex cable
    • Charging Dock board flex cable - remove the foam and tape, then flip up the black lock before easing out the flex.
    • Coaxial antena cable - take your time here, be sure to pull the metal connector and not the cable or you risk pulling the cable from the connector.
    • Remove the 2x Torx T4 screws.
    Take care when removing the coax connector. Mine was very tight and I managed to disconnect the coax cable from the connector. Phone is now in the bin :-(
    keithellis - crwdns2934203:0crwdne2934203:0
    Also, when removing the charging dock board flex cable, the connector has a black lock arm. Remove the foam pad and tape to reveal the lock. Gently ease the lock arm up then ease the flex out.
  5. Microsoft Lumia 535 Logic board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Lumia 535 Logic board Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Lumia 535 Logic board Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert wisdom here.
    With the camera/logic board removed then don’t forget to remove the other end of the charging dock board flex cable from the charging board. When reassembling I found it awkward to hold the protective black guard over the flex out of the way when sliding the end of the ribbon into the replaced charging dock board: combination of tweezers and fingernail required.
    Thomas Goodfellow - crwdns2934203:0crwdne2934203:0
crwdns2935229:08crwdne2935229:0
ZFix
crwdns2935283:012/09/13crwdne2935283:0
194.787 crwdns2915208:0crwdne2915208:0
crwdns2935297:0330crwdne2935297:0
Master Techs crwdns2935289:0Master Techscrwdne2935289:0
Community
crwdns2931471:0327crwdne2931471:0
crwdns2935297:01.423crwdne2935297:0
How can I add additional sensors- the gyroscope & compass chips on this logic board?
Abinash Pal - crwdns2934203:0crwdne2934203:0
microsoft lumia 535 chargeing ic complete
Sunitha Kunapareddi - crwdns2934203:0crwdne2934203:0
my Microsoft lumia 535 chargeing ic complient main mother board lo problem
My microsoft mobile 1090 is not displaying apps but on backlight
Please what can I do to it?
aribasoyeifeoluwa - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 11
crwdns2942667:0crwdne2942667:0 6,054
