Lumia 535
RM-1090 / RM-1091/ RM-1089 / RM-1092
If you have a problem with the charging port or the microphone you have to change Microsoft Lumia 535 Charging Port Dock and Microphone Flex.
crwdns2936621:0crwdne2936621:0
Turn off the phone.
Remove the battery and any SIM and memory cards.
With a screwdriver Torx T4 remove the 9x screws.
With a plastic opening tool separate the back cover from the middle frame.
Disconnect:
Touch screen flex cable
LCD Display flex cable
Charging Dock board flex cable - remove the foam and tape, then flip up the black lock before easing out the flex.
Coaxial antena cable - take your time here, be sure to pull the metal connector and not the cable or you risk pulling the cable from the connector.
Remove the 2x Torx T4 screws.
Disconnect the coaxial antenna cable.
The cable is attached at several points to the frame and to the board. Gently remove it.
The board is glued to the main frame by adhesive tape.
Use a hot gun or hair dryer and warm the board.
Now you can easy separate the board from the main frame.
crwdns2935229:016crwdne2935229:0
crwdns2917034:0crwdne2917034:0
where can i get charging port for microsoft lumia 540
