Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement
crwdns2936621:0crwdne2936621:0
  1. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement, Back Cover / Rear Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement, Back Cover / Rear Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn off the phone.
    • Remove the battery and any SIM and memory cards.
  2. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With a screwdriver Torx T4 remove the 9x screws.
  3. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With a plastic opening tool separate the back cover from the middle frame.
  4. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement, Logic board: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement, Logic board: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement, Logic board: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect:
    • Touch screen flex cable
    • LCD Display flex cable
    • Charging Dock board flex cable - remove the foam and tape, then flip up the black lock before easing out the flex.
    • Coaxial antena cable - take your time here, be sure to pull the metal connector and not the cable or you risk pulling the cable from the connector.
    • Remove the 2x Torx T4 screws.
  5. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert wisdom here.
  6. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement, Charging Port Dock and Microphone Flex: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement, Charging Port Dock and Microphone Flex: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement, Charging Port Dock and Microphone Flex: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the coaxial antenna cable.
    • The cable is attached at several points to the frame and to the board. Gently remove it.
  7. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The board is glued to the main frame by adhesive tape.
    • Use a hot gun or hair dryer and warm the board.
    • Now you can easy separate the board from the main frame.
    • For the separation process use only plastic tools.
crwdns2935229:016crwdne2935229:0
ZFix
crwdns2935283:012/09/13crwdne2935283:0
195,252 crwdns2915208:0crwdne2915208:0
crwdns2935297:0330crwdne2935297:0
Master Techs crwdns2935289:0Master Techscrwdne2935289:0
Community
crwdns2931471:0328crwdne2931471:0
crwdns2935297:01,435crwdne2935297:0
where can i get charging port for microsoft lumia 540
saurabh pawar - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 14,983
