crwdns2959928:0crwdne2959928:0 ↓This guides shows how to replace the Kinect's microphone panel. This should be done if the microphone doesn't pick up any sound regardless of what you do.
Remove the two plastic strips off the bottom of the main Kinect housing using the metal spudger's sharper side.
Peel off the two Xbox 360 stickers from the bottom of the case to reveal two hidden screws.
Unscrew the six 12mm T10 Torx screws.
Remove the top portion of the case from the rest of the body.
Detach the side portions of the case from the body.
Remove the fan piece from the side of the body. Unplug it from the logic board to fully remove it.
Remove the bottom portion of the case by sliding it out from under the body.
Remove the four 7mm T10 Torx screws (two on each side of the metal body).
Remove the front portion of the case containing the lens coverings for the cameras.
The LED component is connected to the front portion of the case. To disconnect it, just pull it out of its plastic connector.
Unplug the microphone from motherboard.
Pull off the microphone panel and snake the cable that was connected to the motherboard through the hole on the camera panel.
