The LCD screen is located directly on top of the motherboard and is attached by a cable underneath, which will need to be removed as well to replace the screen
Warning: The following guide is likely to ruin the water resistance of the device.
Heat the iOpener. Instructions on how to do this can be found here: iOpener Instructions
Firmly press the frame of the band against the iOpener, and hold it in place for about 90 seconds.
Using a spudger, lightly press upwards against one corner of the frame, then the other along the corner of the short edge.
Alternating between the same two corners, continue pressing until there's about a 1-2 mm gap between that end of the frame and the body.
Insert the spudger into the gap under the frame, and lightly slide it about 3/4 of the way down one of the long edges, then repeat with the other.
If the frame doesn't simply pop off, try sliding the spudger the rest of the way down the long edges, and lightly lift the frame with your fingers.
Gently lift the LCD screen from the components using your fingertips.
Lightly pry up the black connector from the motherboard using a spudger.
Pull the entire LCD screen gently upward to detach the yellow ribbon cable.
Where do you buy the lcd screens from?
