Microsoft Band Battery Replacement
    1. Microsoft Band Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew both side panel 2mm screws using the T3 Torx screwdriver.
    2. Microsoft Band Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Firmly pry up the side panel using the plastic spudger to break the waterproof seal and lift the battery panel.
    3. Microsoft Band Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently pry up one edge of the battery with the plastic spudger.
    4. Microsoft Band Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove battery from its compartment with your fingers.
To reassemble your device, follow these instructions in reverse order. Replace the vibrator in its original compartment.
crwdns2935229:05crwdne2935229:0
Monique Salinger
crwdns2935283:002/01/15crwdne2935283:0
408 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 17-34, Amido Winter 2015 crwdns2935289:0Cal Poly, Team 17-34, Amido Winter 2015crwdne2935289:0
CPSU-AMIDO-W15S17G34
crwdns2947412:05crwdne2947412:0
where can i buy the battery?
chirac - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
From what I can tell it's something like this:
http://www.alibaba.com/product-detail/Ho...
which is a 3.7v flat lithium ion polymer 72mAh battery. Min order is 1030 though! You can find similar on AliExpress if you search for that description. The dimensions are listed as 4*14.8*21.5mm so it'll need to be within that, or maybe the OP can confirm the battery size?
Simon - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Anyway to upgrade to a higher capacity battery to get better life out of it? With GPS on, it dies in 2 hours and I go on 8 hr hikes.
Chris Green - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
No tak wszystko fajnie ale gdzie te akumulatory zakupić ?
Tomasz Sot - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 130
crwdns2942667:0crwdne2942667:0 12,768
