crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Microbot Pushcrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Microbot Push Teardown, Opening the casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microbot Push Teardown, Opening the casing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microbot Push Teardown, Opening the casing: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Removing the 4 Torx screws and 1 regular one beneath the black rubber pad shows us a gearbox, 2 PCBs and a battery
  2. Microbot Push Teardown, Battery management: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microbot Push Teardown, Battery management: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microbot Push Teardown, Battery management: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • According to its specs, the MicroBot has a battery life of about one year. The battery is rechargeable, using a regular 5V charger with a micro USB connector.
    • Battery charging circuit
    • Charging IC
    • Transistor to control the red and green LEDS next to the USB port, indicating whether or not the battery is fully charged
    • Battery protection circuit
    • These types of ICs are used to “sense” the current
    • When the specified current limit has been reached they trigger a switch that will break the current path to the battery. The switch that is triggered in this case is a Dual N-Channel Enhancement Mode Power MOSFET, in this case the 8205A
  3. Microbot Push Teardown, Capacitive touch: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microbot Push Teardown, Capacitive touch: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The capacitive touch button and matching circuitry (marked in red)
    • The big gold circle you see in the middle of the PCB is a capacitive touch button. It’s simply an exposed piece of copper
    • The TTP223B chip, this chip is a one-key touch pad detector that can detect the touch of a human finger on the touch pad. It does this by using the “Frequency Change” method
  4. Microbot Push Teardown, Bluetooth: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microbot Push Teardown, Bluetooth: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The bluetooth chip and antenna (I had to remove a metal shield to reveal the chip;)
    • The bluetooth chip, in this case the nRF51822 Nordic Semiconductors (It’s a 2.4GHz ultra low-power bluetooth chip built around a 32-bit ARM® Cortex™ M0 CPU)
    • To the right of the nRF51822, you can see two oscillators, one 16MHz and one 32.768kHz (marked in orange), which generate the clock waveforms for the CPU
    • On the bottom (marked in yellow) you see the antenna circuitry and the PCB antenna itself. As you can see, they did not use a balun chip, but instead created a matching network using some capacitors and inductors.
  5. Microbot Push Teardown, Driving the motor: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This circuit is located on the back of the PCB
    • I could not trace back the datasheets of the actual components used, but after probing the upper IC with an oscilloscope I noticed that this is also a voltage regulator. This one boosts the voltage from 2.5 volts back to 4 volts to power the motor and the motor controller
    • Motor driver
  6. Microbot Push Teardown, Gearbox: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microbot Push Teardown, Gearbox: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microbot Push Teardown, Gearbox: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Opening up the gearbox was fairly simple: I just had to remove two screws to expose the gears and the motor
    • If we count all teeth of the gears we come up with a speed reduction of 948.41
November Five
crwdns2935283:008/25/16crwdne2935283:0
465 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 3,240
