Micro-USB Port Replacement
    1. Micro-USB Port Replacement, Back Plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Micro-USB Port Replacement, Back Plate: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unscrew the four 3.4 mm flat head screws
    2. Micro-USB Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully lift the back plate off the watch. You will notice a lithium battery and rubber gasket attached to the back plate.
    1. Micro-USB Port Replacement, Lithium Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • If not replacing lithium battery, skip down two steps.
      • Using the plastic removal tool, pry the battery from the backing plate. The battery is simply attached with glue.
    2. Micro-USB Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Desolder the battery connections from the motherboard. Learn how to solder components here!
    1. Micro-USB Port Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use PH00 screw driver to remove two 2.4mm Phillips head screws.
    2. Micro-USB Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a spudger or tweezers to remove a white sticker that covers a Phillips head screw.
    3. Micro-USB Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use PH00 screwdriver to remove 5.2mm Phillips head screw
    4. Micro-USB Port Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Micro-USB Port Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Micro-USB Port Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use ESD safe tweezers to remove the gold ribbon cable.
      • This will expose a second 5.2mm Phillips head screw that can be removed with a PH00 screwdriver.
    5. Micro-USB Port Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Micro-USB Port Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a spudger to gently pry on the motherboard towards the top of the watch, being towards the 12 o'clock position to loosen the motherboard.
      • You can now access the parts and pieces on the bottom of, and below the motherboard.
    1. Micro-USB Port Replacement, Micro-USB Port: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the four main soldering points marked in red.
      • Be aware of the five additional soldered pins marked by the blue arrow.
    2. Micro-USB Port Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Micro-USB Port Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Micro-USB Port Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Begin to desolder the points pointed out in the last step.
      • Use the soldering wick to help remove the solder.
Michael Miller
crwdns2935283:010/24/16crwdne2935283:0
281 crwdns2915208:0crwdne2915208:0
IUPUI, Team 3-3, Baechle Fall 2016 crwdns2935289:0IUPUI, Team 3-3, Baechle Fall 2016crwdne2935289:0
IUPUI-BAECHLE-F16S3G3
crwdns2935297:096crwdne2935297:0
I want to know that what I have to do if want to replace the lithium battery with usb direct powered device.
amupis232389 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 45
crwdns2936753:030crwdne2936753:0 204
crwdns2942667:0crwdne2942667:0 18,698
