This is a simple guide on replacing a joystick on a Miadore Classic N64 Controller. If the joystick is out of place or used up, this guide will help you resolve your issue. This guide can also be used if you just want to change the joystick as a design choice.
Use a Phillips #000 screwdriver to remove all nine 3.2 mm screws from the back of the controller.
Place the end of a spudger in the seam between the top and bottom of the controller to release the clips holding them together.
Separate the top and bottom cover of the controller.
Remove the three 3.2 mm Phillips #000 screws holding the motherboard in place.
Remove the three 3.2 mm Phillips #000 screws holding the joystick module in place.
Remove the joystick module.
Remove the joystick by pulling it away from the plastic needle-like object holding it in place.
To reassemble your device, follow these instructions in reverse order. If all goes well, the joystick should work good as new.
