MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement, Determine the unloader assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement, Determine the unloader assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement, Determine the unloader assembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There are two versions of the unloader assembly:
    • First image—earlier pressure washers feature an all-in-one assembly (part 8-0631) that’s easy to replace, but gave users the ability to break the pump.
    • Second image—later models use a tamper-proof, harder to remove unloader (part 8-0656), connected by a series of pipe fittings.
    • This guide is written for the tamper-proof unloader assembly.
    • If you need to remove an all-in-one style unloader, use a large adjustable wrench to unscrew the two large Banjo bolts. This will disconnect the unloader from the pump assembly.
  2. MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, be sure that the engine is powered off and is cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  3. MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement, Loosen the hose clamp: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement, Loosen the hose clamp: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 1/4" socket or a large flathead screwdriver to loosen the hose clamp near the inlet filter.
    • Slide the hose clamp away from the end of the hose.
  4. MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement, Disconnect the return hose: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement, Disconnect the return hose: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wiggle the hose and pull it off of the brass nipple.
  5. MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement, Position the support block: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide a 3" tall block underneath the pump assembly to help support the pump.
  6. MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement, Re-position the return elbow: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement, Re-position the return elbow: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 1/2" or adjustable wrench to loosen and twist the return elbow half a turn, so that it faces the opposite direction.
    • This will allow the fitting to clear the pump edge without being removed.
  7. MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement, Loosen the filter: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement, Loosen the filter: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a large adjustable wrench to loosen and unscrew the filter.
  8. MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement, Remove the filter: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the filter with the return elbow attached.
  9. MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement, Loosen the input elbow: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement, Loosen the input elbow: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 1" or large adjustable wrench to loosen and unscrew the pump input elbow.
  10. MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement, Remove the input elbow: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the input elbow fitting.
  11. MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement, Loosen the output assembly: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement, Loosen the output assembly: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 3/4" or adjustable wrench to loosen and disconnect the coupling from the pump assembly.
  12. MiTM Pressure Washers CA2703HDHB1 2017 Output Assembly Replacement, Remove the output assembly: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the output assembly.
When you re-connect the fittings, clean off the old thread sealant and apply new thread sealant (tape or pipe dope).
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
298,760 crwdns2915208:0crwdne2915208:0
crwdns2935297:0684crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,959crwdne2935297:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 32
