MiTM Pressure Washer CM1400HDEC1 2017 Power Switch Replacement
  1. MiTM Pressure Washer CM1400HDEC1 2017 Power Switch Replacement, Disconnect all hoses and unplug the power cord: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MiTM Pressure Washer CM1400HDEC1 2017 Power Switch Replacement, Disconnect all hoses and unplug the power cord: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect all hoses and unplug the power cord before performing any repairs on the Mi-T-M electric pressure washer.
  2. MiTM Pressure Washer CM1400HDEC1 2017 Power Switch Replacement, Unscrew the electrical box: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 59.2 mm-long 4 mm hex socket bolts from the electrical box.
  3. MiTM Pressure Washer CM1400HDEC1 2017 Power Switch Replacement, Lower the electrical box: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MiTM Pressure Washer CM1400HDEC1 2017 Power Switch Replacement, Lower the electrical box: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pull the electrical box away from the engine until you have enough space to work inside it, making sure not to strain the cables that are still connected inside.
    • If you have trouble lowering the electrical box, you can disconnect the green power cord wire for more slack.
  4. MiTM Pressure Washer CM1400HDEC1 2017 Power Switch Replacement, Disconnect the wires attached to the power switch: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MiTM Pressure Washer CM1400HDEC1 2017 Power Switch Replacement, Disconnect the wires attached to the power switch: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MiTM Pressure Washer CM1400HDEC1 2017 Power Switch Replacement, Disconnect the wires attached to the power switch: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the four wires running to the backside of the power switch.
    • These wires may be difficult to remove. If necessary, you can use a pair of pliers to gently pull them up off their contact rails.
  5. MiTM Pressure Washer CM1400HDEC1 2017 Power Switch Replacement, Pry out the power switch: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MiTM Pressure Washer CM1400HDEC1 2017 Power Switch Replacement, Pry out the power switch: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MiTM Pressure Washer CM1400HDEC1 2017 Power Switch Replacement, Pry out the power switch: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a flathead screwdriver or a pry tool to pry the power switch away from the electrical box.
  6. MiTM Pressure Washer CM1400HDEC1 2017 Power Switch Replacement, Remove the power switch: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MiTM Pressure Washer CM1400HDEC1 2017 Power Switch Replacement, Remove the power switch: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the power switch from the electrical box.
Taylor Dixon
crwdns2935283:006/26/18crwdne2935283:0
70,343 crwdns2915208:0crwdne2915208:0
crwdns2935297:094crwdne2935297:0
crwdns2936753:030crwdne2936753:0 45
crwdns2942667:0crwdne2942667:0 1,695
