MiTM Air Compressors AM1PH6508HD 2012 Valve Plate Replacement
  1. MiTM Air Compressors AM1PH6508HD 2012 Valve Plate Replacement, Turn off the engine: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MiTM Air Compressors AM1PH6508HD 2012 Valve Plate Replacement, Turn off the engine: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, make sure the device is powered down and cool to the touch.
    • Flip the engine switch into the OFF position.
  2. MiTM Air Compressors AM1PH6508HD 2012 Valve Plate Replacement, Disconnect the spark plug: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MiTM Air Compressors AM1PH6508HD 2012 Valve Plate Replacement, Disconnect the spark plug: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  3. MiTM Air Compressors AM1PH6508HD 2012 Valve Plate Replacement, Drain the compressor tank: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MiTM Air Compressors AM1PH6508HD 2012 Valve Plate Replacement, Drain the compressor tank: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the ring on the safety relief valve away from the compressor tank to drain the air from the compressor.
    • Ensure the tank is completely depressurized before starting repairs.
  4. MiTM Air Compressors AM1PH6508HD 2012 Valve Plate Replacement, Disconnect the pump discharge line: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 7/8 inch wrench to loosen the nut securing the pump discharge line to the elbow on the cylinder head.
  5. MiTM Air Compressors AM1PH6508HD 2012 Valve Plate Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MiTM Air Compressors AM1PH6508HD 2012 Valve Plate Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the pump discharge line from the elbow.
  6. MiTM Air Compressors AM1PH6508HD 2012 Valve Plate Replacement, Remove the belt guard cover bolt: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 10 mm socket to remove the bolt securing the belt guard.
  7. MiTM Air Compressors AM1PH6508HD 2012 Valve Plate Replacement, Remove the belt guard cover: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MiTM Air Compressors AM1PH6508HD 2012 Valve Plate Replacement, Remove the belt guard cover: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MiTM Air Compressors AM1PH6508HD 2012 Valve Plate Replacement, Remove the belt guard cover: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Tilt the belt guard away from the device and lift it out to remove it.
  8. MiTM Air Compressors AM1PH6508HD 2012 Valve Plate Replacement, Remove the belt guard bracket bolts: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 7/16 inch socket to remove the nuts and accompanying bolts securing the belt guard bracket to the rear belt guard.
    • You may need to hold the bolts in place with a 7/16 inch wrench during removal.
    • Don't misplace the washers that are removed during this step.
    • During reassembly, you may need to slightly loosen the two head bolts securing the belt guard bracket in order to properly align the bracket with the mounting holes in the rear belt guard.
  9. MiTM Air Compressors AM1PH6508HD 2012 Valve Plate Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 1/2 inch socket to remove the two bolts securing the belt guard bracket to the cylinder head.
    • Don't lose the loosened spacers underneath the belt guard bracket.
  10. MiTM Air Compressors AM1PH6508HD 2012 Valve Plate Replacement, Remove the belt guard bracket: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MiTM Air Compressors AM1PH6508HD 2012 Valve Plate Replacement, Remove the belt guard bracket: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the belt guard bracket straight up to remove it.
  11. MiTM Air Compressors AM1PH6508HD 2012 Valve Plate Replacement, Remove the spacers: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MiTM Air Compressors AM1PH6508HD 2012 Valve Plate Replacement, Remove the spacers: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four spacers from the top of the cylinder head.
  12. MiTM Air Compressors AM1PH6508HD 2012 Valve Plate Replacement, Remove the four bolts on top of the cylinder head: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 1/2 inch socket to remove the four remaining bolts securing the cylinder head:
    • Two 2 1/8 inch-long bolts
    • Two 2 1/2 inch-long bolts
    • During reassembly, install all six head bolts at once, and only until hand-tight. Then, fully tighten the six bolts in a star pattern.
  13. MiTM Air Compressors AM1PH6508HD 2012 Valve Plate Replacement, Remove the cylinder head: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MiTM Air Compressors AM1PH6508HD 2012 Valve Plate Replacement, Remove the cylinder head: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the cylinder head.
  14. MiTM Air Compressors AM1PH6508HD 2012 Valve Plate Replacement, Remove the gasket: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MiTM Air Compressors AM1PH6508HD 2012 Valve Plate Replacement, Remove the gasket: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the gasket from the cylinder head.
  15. MiTM Air Compressors AM1PH6508HD 2012 Valve Plate Replacement, Remove the valve plate: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MiTM Air Compressors AM1PH6508HD 2012 Valve Plate Replacement, Remove the valve plate: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MiTM Air Compressors AM1PH6508HD 2012 Valve Plate Replacement, Remove the valve plate: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push up on one of the valve plate tabs to break the seal between the valve plate and the gasket.
    • Remove the valve plate.
  16. MiTM Air Compressors AM1PH6508HD 2012 Valve Plate Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MiTM Air Compressors AM1PH6508HD 2012 Valve Plate Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the bottom valve plate gasket from the top of the cylinder.
    • Use a shop towel to remove any remaining pieces of the gasket on top of the cylinder.
    • Use compressed air to remove any gasket debris or other small particles from inside the cylinder.
    • During reassembly, note that the two gaskets in the valve plate kit are fragile. Bending the gaskets may cause them to break.
Kyle Smith
crwdns2935283:002/01/21crwdne2935283:0
46,465 crwdns2915208:0crwdne2915208:0
crwdns2935297:0123crwdne2935297:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 287
