MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement
  1. MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement, Turn off the engine: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement, Turn off the engine: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, make sure the device is powered down and cool to the touch.
    • Flip the engine switch into the OFF position.
  2. MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement, Disconnect the spark plug: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement, Disconnect the spark plug: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  3. MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement, Drain the compressor tank: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement, Drain the compressor tank: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the ring on the safety relief valve away from the compressor tank to drain the air from the compressor.
    • Ensure the tank is completely depressurized before starting repairs.
  4. MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement, Remove the pressure gauge: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 7/16 inch wrench to loosen the nut securing the pressure gauge to the regulator housing.
  5. MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the pressure gauge.
  6. MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement, Loosen the adjustable regulator: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement, Loosen the adjustable regulator: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement, Loosen the adjustable regulator: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Fit an adjustable wrench to the black metal square on the hose side of the regulator.
    • Use a 3/4 inch wrench to hold the nipple in place.
  7. MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the adjustable wrench to break the regulator loose from the threaded nipple.
  8. MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Fit an adjustable wrench to the black metal square on the bracket side of the regulator.
    • Use an 11/16 inch wrench to hold the hose barb.
  9. MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Break the hose barb fitting loose from the regulator.
  10. MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement, Remove the two regulator mounting bracket bolts: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement, Remove the two regulator mounting bracket bolts: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 1/2 inch socket and wrench to remove the two bolts and accompanying nuts securing the regulator mounting bracket to the frame.
    • Don't forget to remove the two washers as well.
  11. MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement, Unscrew the regulator mounting bracket: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement, Unscrew the regulator mounting bracket: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement, Unscrew the regulator mounting bracket: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the regulator off of the mounting bracket.
    • Use your fingers to unscrew and remove the mounting bracket from the regulator.
  12. MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement, Unscrew the adjustable regulator: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement, Unscrew the adjustable regulator: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement, Unscrew the adjustable regulator: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the adjustable regulator from the hose barb.
    • Remove the regulator.
  13. MiTM Air Compressors AM1PH6508HD 2012 Regulator Replacement, Remove the regulator plug: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 3/16 inch hex key to remove the plug from the regulator.
    • Only the regulator remains.
Kyle Smith
crwdns2935283:002/01/21crwdne2935283:0
46.157 crwdns2915208:0crwdne2915208:0
crwdns2935297:0123crwdne2935297:0
crwdns2942667:0crwdne2942667:0 412
